a little smokey
Discussion in 'Forced Induction' started by madvtec_2008, Mar 7, 2008.
  1. madvtec_2008
    madvtec_2008 VTEC YO!
    North Dakota
    I started my b16 turbo for the first time last night in about 4 months cuz ive been building it....ran a little boggy at first while idling but came out of it...idled nice...when i'd get the r's up it would smoke a little out of the valve cover and the pcv cuz i had to re-rout it so it would go to the intake of my turbo....what are your guys' ideas?
  2. Briansol
    you put the pvc to the intake of the turbo?????????????
    wtf
  3. amadeuscr
    amadeuscr Member
    full words please :p , what is pvc ?
  4. madvtec_2008
    North Dakota
    its pcv and it means positive crank ventilation....and yes i hooked it up to a nipple on the intake for the turbo because i cant keep it connected to the intake manifold because it will be pressurized and the crank case cant be pressurized or else shit will go bad
  5. amadeuscr
    amadeuscr Member
    between the line that goes from intake manifold to the crank gas catch box , there is a valve that avoids pressure to go in to the direction of the crank, actually is attached to the intake manifold close to the inyectors !
  6. madvtec_2008
    North Dakota
    thanks for the heads up...ill have to check it out....but what do you think about the smoke? ...i was thinking blow by...but there new rings...but i was thinking if i didn't have the ring gap (not) lined up...so thats what i was thinkin
  7. YBLEGAL
    YBLEGAL Regular Member w/ Cheese
    NW Indiana
    The PCV is a one way valve, which keeps boost from doing what your thinking, when it overcomes vacuum.
    But in that same frame of mind, didn't you think the same thing would happen to your brake booster?
    I don't know what your smoke is. I don't know how hard you've drivin it. Seems to me you don't have the waste gate hooked up properly. Maybe you ruined the rings. idk
  8. Briansol
  9. madvtec_2008
    North Dakota
    yeah thats what i was thinkin too...:S but i pulled the pistons and the ring gaps were very close so im guessing that it was blow by because of the rings and i did a compression test on them and the two i checked that had low compression has the messed up rings....does anyone know what the compression should be for 8.5:1 C/R?
  10. YBLEGAL
    NW Indiana
    [FONT=verdana,geneva][FONT=verdana,geneva][FONT=verdana,geneva]Compression test results should be as follows:[/FONT][/FONT][/FONT][FONT=verdana,geneva][FONT=verdana,geneva]
    • [FONT=verdana,geneva]8:1-8.5:1 compression: 150-170 psi per cylinder[/FONT]
    • [FONT=verdana,geneva]8.5:1~9.5:1 compression: 170-210 psi per cylinder[/FONT]
    • [FONT=verdana,geneva]9.5:1~11:1 compression: 210-275 psi per cylinder[/FONT]
    • [FONT=verdana,geneva]11:1+ compression: 250+ per cylinder (highly depends on cams being used)[/FONT][/FONT][/FONT]
    [FONT=verdana,geneva][FONT=verdana,geneva][FONT=verdana,geneva]:thumbsup:[/FONT][/FONT][/FONT]
  11. madvtec_2008
    North Dakota
    THANKS!:D
