a question for all opinions
Discussion in 'General Tech and Maintenance' started by HondaMoCo, Feb 4, 2006.
  1. HondaMoCo
    HondaMoCo Senior Member
    lancaster/palmdale So Cal
    here is the question...lets say you checked your lug nuts, and all 4 on one tire were finger tight...you are absolutely positive a short time ago you tourqued them down all the way, not a shadow of a doubt...all the studs are fine not stripped...all the lugs are fine, not stripped....what would you guys be thinking??? all answers welcome...all your guys answers are appreciated...thanks
  2. mikeislord
    mikeislord Senior Member
    Piscataway, NJ
  3. HondaMoCo
    thanks for the opinions guys...im going to put them back on keep my eye on them...and if everything is pee chee i have an idea of what or who could have happened
  4. LudeBoy
    LudeBoy Slave to the EF
    STL
    Are the rims aluminum? If so thats normal. You should check tq on lug nuts on alum wheels whenever there is a big temp change, or after every oil change.
