A-typical Swaps
Discussion in 'Other Vehicle Discussions' started by utn, Jun 6, 2005.
  1. utn
    utn Member
    What other kinds of cars do people put Honda engines into? :p
    I'm looking into buying a Pointiac Fiero or a Lotus Esprit (1st gen.. S1?) and if a swap is feasible, getting into it.
    I like those cars but they could use the greater power and reliability of a Honda engine.
    I'm pretty sure it would take a bit of modifications to do. Like super custom mounts or welding in new mount points. Custom shift linkages, modified clutch & throttle cables and so on.
    What's everyone's take on it?
    Thanks,
    Scott
  2. jamesA
    I've seen people ask on feoa.net about putting a B18c5 into a 91-96 Escort GT.
  3. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    for a MR car, you will have to consider on how to shift the gears. For an H22 or a k20, it wouldn't be too hard because you could run a pully system, but your your going to have to become really crafty if you want an engine with a solid shift linkage.
  4. reikoshea
    Dallas, TX
    A friend of mine in CT swapped a Supercharged V8 Northstar (out of a deville i think) into a fierro and its friggin sweet. I think he said he was posting high 11s which is pretty damn cool for a fierro.
    But in honda area the B18 would be sweet in something like a Mazda 323 or a Toyota Trecel (ultimate sleeper with some good engine work)
  5. jamesA
    As long as the 323 is the FWD version it'd work, but you'd be wasting your time putting a b18c into an awd 323GT.
  6. utn
    utn Member
    I was looking at cars which either had rear engines already or were cool looking FWD cars. I also thought it would be wicked to drop a B18c into a DeLorean and give it some pep. But DeLoreans aren't as cheap as a Fiero. ~$10k <_<
    B18c DeLorean would be a pretty cool sleeper too, heck why not put a JDM H22 in it.
  7. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    A B18C wouldn't give a Delorean any "pep", it weighs just over 2700lbs, and has 65% of the weight in the rear.
  8. 97SIRTN
    97SIRTN Member
    There was a Lotus with a b18c swapped in in one of my old Car and Drivers. Or maybe it was in Super Street. Couple of years ago any way. Might have been a type R, cuz it had the red valve cover. It was a tight fit, but it looked sweet. And I like Lotus'.
  9. pissedoffsol
    yeah, in the elise, which is sub 2000 lbs. lol
    you're going to hate life with a 160 hp dog sled that gets smoked by street kiaz
  10. asmallsol
    Exactly. Remember, hondas can be quick and handle well because the civic is a pretty light car. Things like Mustangs and Camaros make a TON of power stock, but because they are like 70% heavier, they are about as quick as then lets say a GSR hatch. If you threw a built NA GSR in a mustang or a camaro, the thing wouldn't even be fast enough to get out of its own way. Hell hills would probally be a challenge. 180hp in a 3000+lb car = slow as hell. 180hp in a 1500lb car = bat out of hell.
    LS1 in almost any car will make it go fast. GSR will make light cars go fast.
  11. EGProject
    EGProject YEEEEAAHHHHH
    Whitinsville, Massachusetts
  12. B16
    B16 Super Moderator VIP
    yay area, CA
    Haha, for real.
    You shouldn't bother swapping a b18c into anything that weighs more than 2400lbs.
  13. phunky.buddha
    Dallas / Fort Worth, TX
    B20 into a Karmann Ghia. That or an EJ22. We'll see.
  14. reikoshea
    Dallas, TX
    i wanna see a 2JZ in a 86 corolla if you ask me
  15. Battle Pope
    Battle Pope New Member
    Southern Oregon Coast
    Holy handling nightmare, batman!
  16. reikoshea
    Dallas, TX
    just because the 2JZ has more torque than the NSX thats no reason why the handling would suck. :D
  17. Battle Pope
    It's called taking a 1.8 liter 4-cyl and replacing it with an iron block TT inline 6 that weighs probably 200-300 lbs more and dropping it on the nose of a perfectly balanced car.
  18. reikoshea
    Dallas, TX
    LOL...TOTALLY wasnt thinking of it that way...yeah good catch...still think it would be cool though.
  19. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    well theyve(the japs) have dropped a turbo tri-rotor 20b in a ae86 corolla; imo that is better than dropping in the 2jz.
  20. racintweek
    racintweek Senior Member
    Arlington VA
    PRETTY DAMN CLOSE i'm sure any flat engien will fit in there
