A-vtec
Discussion in 'Members' Lounge' started by pissedoffsol, Mar 7, 2007.
  1. pissedoffsol
  2. Celerity
    Celerity Well-Known Member
    Bookmarked for later read. Isn't this what's found in the Fit ?
  3. eg6sir
  4. reckedracing
    reckedracing TTIWWOP VIP
    NY
    i don't think this is whats in the fit
    i don't think its in production yet
    i thought there were other constant variable systems that just BMW
    didn't lambo or ferrari have a continually variable valve system?
  5. get_nick
    Washington State
    i tried to read it and it went wayyyy over my head.
  6. Celerity
    Ferrari's variable valve system is a result of the valves being bent, loose and out of lash every 10 miles.
  7. klyph
    klyph Dismember VIP
    North Pole, AK
    Wowzor.
    With all that added complexity to the head, I would think it'd be a lot simpler to make the valves actuated by electronic solenoids controlled by the ECU. :shrug:
    WTF do I know.
  8. reckedracing
    NY
    i dunno if an electronic solonoid can put out 8K actuations per minute
  9. Celerity
    Aura (Makers of the speakers and AuraGen alternators) makes a solid state valve head. (Well.. solid to the solenoids)
    But when you think of it, it's a speaker. 8,000 hz ? Why not ?
  10. klyph
    klyph Dismember VIP
    North Pole, AK
    Injectors can pulse at those RPM's. Just scale it up a bit.
  11. reckedracing
    NY
    but how heavy is that setup going to be compared to a camshaft and rockers
  12. klyph
    klyph Dismember VIP
    North Pole, AK
    The A-VTEC probly won't add much over regular VTEC, but a solenoid activated system would be WAY lighter- no cams, rockers, cam pulleys, timing belt, plus all the material in the head used to support the cams. Come on Honda, DOOOO IT!
  13. reckedracing
    NY
    i think this will be a big improvment over vtec
  14. klyph
    klyph Dismember VIP
    North Pole, AK
    I meant that it wouldn't add much WEIGHT. The performance/economy gains would obviously be drastically improved.
  15. cheese9988
    cheese9988 Senior Member VIP
    Lowell, MA
    They can make an acutator to do that, but to get them that fast with that much force against a spring would require alot of power. More electrical power would require a larger alternator. Then there is the reliability part, probably need bigger coils, the solenoids will get very large. Honda probably wants a simple, lightweight and reliable design.
  16. phunky.buddha
    Dallas / Fort Worth, TX
  17. tab
    tab Super Moderator
    Aberdeen, Washington State
