A6 head swap>which distributor
Kracer427
just recently picked up a nice d16a6 head that i'm planning on putting on my '92 cx. What kind of distributor is needed for the head? Do i use the Si one or could i use one from a z6? I guess what i want to know is will the wiring be straight forward and all i need to do is swap out the ecu? The plugs look alot different and i'm not sure if you can put a OBD0 part up to a OBD1 harness. Thanks for your help. Who needs VTEC anyways..... :p
