a6y8 dizzy help what one?
cardinalboy07
dizzy help for a6y8 what one?
ok i finished wiring up my ef from dpfi to mpfi.....the part im stuck at is what distributor to use i did research and ppl say use d15b7 dizzy..but dont line up... some say use y8 dizzy...
heres my set up i got a obd1 dizzy from a 95 civic but doesnt line up..what do i do?
y8 head off 97 civic
y8 intake mani off 97 civic
chipped p06 ecu with jumper harness
a6 block 91 civic
odb2 injectors and clips (high inde)
i converted to odb1 and i have a B7 dizzy but one of the ears dont line up the other two do
B7 distributor should bolt right up to Y8 head
what model is your distributor?
D15B7 is TD-41U
D16Z6 is TD-42U
