About cleaning injectors
Discussion in 'General Tech and Maintenance' started by CRAZYEG9, Nov 28, 2004.
  1. CRAZYEG9
    CRAZYEG9 Senior Member
    The five boroughs
    Okay, I'm doing an ODD2 bseries swap in my 92 Civic, so I'm going to use the injectors in my d15b7 engine and put them on the Bseries engine since I can't use the OBD2s. The question is can I clean them while there outside of the car (and if I can how) or can I bring them somewhere because 9 times out of 10 they're dirty.
  2. civic93
    civic93 Junior Member
    you need bigger injectors for the b series they have 240 and gsr are 310 your d15b7 has 190 i think
  3. 92civicb18b1
    92civicb18b1 The Trisexual
    i think they are all 240's, I should have a set of obd1 240's if you want them.
  4. PhyRe
    PhyRe Senior Member
    ct
    i have an obd2 in my 93 why are you changing you injectors?
    says who? as long as you have everything from the obd2 (execpt ecu) everything is plug and play
  5. 92civicb18b1
    Since I'm confused now...
    You're better off making it OBD1. There are a couple of peices you need to replace, someone can tell you exactly. I only can think of injectors, o2 sensor, dizzy and i dunno knock sensor.
    I never did the obd2-1 conversion. The obd0 to 1 was pretty simple, injectors and dizzy, and a couple other little things.
  6. sleepercivic
    sleepercivic Senior Member
    NC Mountains
    could he just use an obd2 integra harness and an obd1 ecu, I think you may have to repin a wire or 2 but the integra harnesses plug into 92-95 shock towers. That way he could use OBD2 components(injectors dizzy), without cutting splicing
    Someone please correct if I am wrong, but I believe I read this on HT, they were discussing a type r into 92-95
  7. nfn15037
    nfn15037 Senior Member
    You are wrong, all B and D series are 240, preludes are 270...310s in a GSR?! lol
  8. CRAZYEG9
    The five boroughs
    You seem the smartest. I don't know where civic93 got that BS info from cause B & Ds are both 240cc. What do you think about my question.
  9. Arachnid
    Arachnid Senior Member
    somebody back me up! i'm thinking maybe you can just do the whole swap and use an obd2-obd1 conversion harness and use a p28 or p30 ecu (vtacc yo!!) imo that'll be the easiest way to go. as for your injectors try to talk to rc or something...i'm sure there are places that flow and balance them. try napa even
    and not all injectors are 240cc. there are distant engines that use 190cc...this is outa date engine.
  10. nfn15037
    OK, here is what you need to do: Use the stock harness that is in your car, all the OBDII sensors will work with a OBDI ECU and use the D series injectors. Just swap it like any other swap and use a chipped P28, P30, P72, or whatever OBDI ECU you want to. RC offers cleaning and balancing services for injectors, it is about a week turnaround time and you get a print out of the injector flow results.
