(?) about making OEM 3 layer gasket.....
Discussion in 'Engine Building' started by gocivicls, Sep 10, 2003.
  1. gocivicls
    gocivicls Senior Member
    forest city, NC
    If I very carefully drill out the rivits in the OEM 3 layer head gasket and remove a layer before installation. I know this will give me higher compresion but do I have to resurface my head or block for a good seal?
    The head gasket I am using is factory replacement, the brand name is JONES.
  2. pissedoffsol
    don't bother.
    you MIGHT see .1 in comression, and chances are it will leak.
  3. phunky.buddha
    Dallas / Fort Worth, TX
    Just go buy one that's already thinner.. I'm pretty sure you can order custom head gasket sizes/thickness from Cometic or other high quality aftermarket companies..
  4. brian11to1
    brian11to1 Senior Member
    A question concerning this thread, what is better for Higher compression engines, a thicker HG, or a thinner HG? Sorry didnt mean to thread jack yO'
  5. phunky.buddha
    Thinner = higher compression
    Thicker = lower compression
    Just build the engine with the right piston specs, and then you don't have to worry about playing with the head gasket to get the compression ratio you want.
  6. gocivicls
    forest city, NC
    Thanks for the info guys! I found Mugen HG 1 layer for $129.00 and Spoon 2 layer $125.00. I have heard of people getting OEM HG and removing a layer, so I wanted to know from the pro's. <_<
  7. gocivicls
    forest city, NC
    199IntegraBuildUpH22A3 did you say!
  8. brian11to1
    gocivicls
    first of all it's an auto, the trans was slipping slightly. I just ran it to run it... for fun... i guess
  9. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    I did take the middle layer out, didn't leak but honestly it wasn't worth the effort.
  10. gocivicls
    forest city, NC
    I want try it. It would suck to tear back down just to replace the HG.
    :p
    Last night I ran a..... 9.10 @ 76.99mph and 60ft 2.00. And remember this track is up hill. I had the best time of any N/A Honda there.
    Still stock internals w/ a gutted 95 coupe dx.
