About The Different Generations
Discussion in 'General Tech and Maintenance' started by jeffg989, Mar 4, 2003.
  1. jeffg989
    jeffg989 Junior Member
    ok, i just bought my first car which is a 93 civic hatchback, so i am just starting to read about all the different stuff you can do to them, because i am new to all this alot of the terminology confuses the crap out of me, so i want to know once and for all what year civics are what generations?
    ps. if your bored and want to explain any other terminology, go right ahead
  2. Domeskilla
    Domeskilla Senior Member
    Fort Wayne, IN
    88-91 civic is the 4th gen (chassis code EF)
    92-95 civic is the 5th gen (chassis code EG)
    96-00 (01?) civic is the 6th gen (chassis code EK)
  3. BlackJDMdeath
    BlackJDMdeath Senior Member
    Wichita, KS
    ef 0wnz. the EF is also known as the soapbox. the eg is the bubble back, not sure about the ek
  4. pissedoffsol
    to take this a step further
    5th gens also include the EH chassis
    and 6th gens have the EJ's
    7th gens are EP
    teg's are DC
    lude's are BB
  5. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    Then generations are not only just body/chassis style, also, ever gen had a diffrent type of On Board Dieignostics (sp)
    4thgen -OBD0
    5th gen - OBD1
    6th gen -OBD2
    There were two styles of obd2, 96-97 was a diffrent plug style (or something small like that) than 98+
  6. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    There is also the:
    AL/AG/AH from 84-88
    EC8 and 9 from 88-91
    EE9 from 90-91 w/B16A1
    EJ coupes from 94-95 as well
    MA8/9 from 96-00
    MB1-9 from 96-00 5 door hatchback/and aerodeck
    MC1/2 aerodeck 98-
    EP1/2/3 from 01- (3 is the type R)
    EU from 01- (5 door hatch)
    EM from 01 coupe
  7. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    Gen 3 Tegs are DC, Gen 2 Tegs are DA
  8. TRuggiero_
    TRuggiero_ Senior Member
    Winter Garbage, Fl
    There's a good 200 different chassis codes. By the way did you guys know that the USDM 92-95 HB is actually an EH? Only the JDM 92-95 HB is EG6. I still call them all EG6's but, just wondered if you guys knew that.
  9. xj0hnx
    C.C.TX.
    The 92-95 EH is the four door and the 94-95 coupe is EJ1/2.And the EG is more than the EG6 in Japan and here in Germany it spans EG3/4/5/6/8/9 depending on trim level.47 chassis codes for civics since 84.
  10. TRuggiero_
    Winter Garbage, Fl
    My 200 estimate is actually closer to 60. It looked a lot bigger when I saw my list.
    EH2- USDM 3-Door CX/DX/VX
    EH3- USDM 3-Door Si
    EH6- USDM Del Sol Si (SOHC)
    EH9- USDM 4-Door EX
    EJ1- USDM 2-Door EX
    EJ2- USDM All 2-Door EX
  11. xj0hnx
    C.C.TX.
    Where did you find that list?The ones I've seen list the HB as EG.
  12. TRuggiero_
    Winter Garbage, Fl
    I got the page in my garage ripped right out of a Honda Shop manual. The EG's are HB's they are just the JDM hatches.
    EG1-D15B -JDM -All 3-Door/4-Door/CR-X
    EG1-D15B8-USDM-1993-1995 Del Sol (8-Valve)
    EG1-D15B7-USDM-1993-1995 Del Sol S (SOHC)
    EG1-D15Z1-USDM-1993-1995 Del Sol VTEC-E (SOHC)
    EG2-B16A -JDM -All 3-Door/4-Door/CR-X
    EG2-B16A3-USDM-1994-1995 Del Sol VTEC (DOHC)
    EG3-D13B -JDM - All 3-Door/4-Door
    EG4-D15B -JDM - All 3-Door/4-Door/CR-X
    EG5-Sumthin with a DOHC ZC? It's crossed out?
    EG6-B16A -JDM - All 3-Door/4-Door/CR-X
    EG7-D13B -JDM -All 3-Door/4-Door
    EG8-D15B -JDM -All 3-Door/4-Door/CR-X
    EG8-D15B7-USDM-All 4-door Dx/LX
    EG9-B16A -JDM -All 3-Door/4-Door/Del Sol CR-X
