about to do an h22 eg swap. cant find DIY sticky.
Discussion in 'HYBRID -> EG-EK / DC' started by hondakid183, Jan 11, 2013.
  1. hondakid183
    hondakid183 New Member
    i have a 95 eg hatch with an h22a and i found anther hatch with a clean body and a cage. that i am going to swap my stuff into. i have been searching for some time trying to find a write on one but i just cant seem to locate it. if anyone knows a site or link please post it so i can print and began this swap. thanks
  2. 916em1
    916em1 New Member
    if u already have a h22 eg then just transfer everything over, simple.
  3. lostsoulzprophet
    lostsoulzprophet delslow
    georgia
    not just as easy as swapping over. most yes but if the other hatch didnt have a h he has to relocate a engine mount. cut and re weld.
  4. josh_crewdson@y
    josh_crewdson@y New Member
    nova
    There are mounts that don't require cut/weld...
    Only thing you should have to cut is a hole for the shifter cables and mount the shifter box.
  5. lostsoulzprophet
    georgia
    didnt know that. not up to date on h swaps. lol =P thanks for the info
  6. josh_crewdson@y
    nova
    Well, I was wrong. for the hasport kit, you have to remove the old passenger trans mount, and drill a couple holes for the new bracket. But that is pretty much cake work.
    LOL, my ek was straight bolt in.
  7. lostsoulzprophet
    georgia
    oooooo. dont sound to bad. might go h one day lol. doubt it but always a possibility
