About to swap a b18b1 into a del sol
Discussion in 'HYBRID -> EG-EK / DC' started by Icefrogg, Feb 5, 2014.
  1. Icefrogg
    Icefrogg New Member
    been gathering parts and this is what I have so far...please let me know if I am missing anything
    the car..93 del sol s model..obd1
    the motor..b18b1 obd2 with matching tranny
    I have:
    motor
    tranny
    ls axles
    ls half shaft
    del sol vtec shift linkage
    obd2 ls wire harness
    obd1 p75 ecu (was told I needed obd1 ecu and distributor to convert from obd2 to 1)
    obd1 ls distributor
    driver side 3 bolt mount
    t bracket for the rear (are these the only two dc2 mounts I need?)
    does this all look good...anything else I am missing? Thanks
  2. Briansol
    There's 3 mounts you need from the integra or del sol vtec, the tranny mount, the rear mid mount, and the drive side mount.
    you're going to need to plug swap the alternator, or get an obd1 alt as well.
    otherwise, looks good. you probably won't even need the ls wireharness since you're swapping on obd1 electronics. use your car's harness.
