above 100 mph my car sways like a boat...
Discussion in 'Wheels / Suspension / Tires / Brakes' started by SPEEDFREAK0920, Oct 8, 2004.
  1. SPEEDFREAK0920
    SPEEDFREAK0920 Senior Member
    chI-t0wn fo0
    i got a 92 hatch with a 1.8 and tokico blues with ground control coilovers. that's the only suspension work i have done to the car. when i go above 100 mph my car pulls left and right really hard. then when i get on the brakes it pulls even more. what's the best way to eliminate this problem? sway bars? front rear strut bars? i'm trying to spend the least amount of money as possible. thanks
  2. phunky.buddha
    Dallas / Fort Worth, TX
    Tie rod ends maybe? Check your alignment, then check everything in your steering system. It sounds to me like something is loose.
  3. tjr5150
    tjr5150 Junior Member
    take it to a front end shop and have them check alignment and supension
  4. micah
    micah Senior Member
    panama city beach, florida
    stay below 100 mph? :p
  5. EGProject
    EGProject YEEEEAAHHHHH
    Whitinsville, Massachusetts
    Bushings maybe? I don't know, but an alignment would be a good idea.
  6. nismogod
    nismogod Senior Member
    Deltona, FL
    baaaaaaaaaahahahhaha.
    this works. i've heard other people speak of the car getting really floaty around 120ish. maybe its an aerodynamic thing? but i'd probably do like the others aer sayin and have it looked at up front.
  7. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    its the coilovers. when i had the fodo on gc's and tokico blues, at the strip it wobbled a li'l bit above 80ish(since i ONLY went over 70 at the strip)...on the hatch, when i went 14.88@92, above around 60 or so it was really floaty, and thats with ground controls on stock struts.
    however, when i had the Tein S-Tech's on the fodo, it didnt float at all.
    sleeve coilovers suck.
  8. phunky.buddha
    Mine's dead on stable at 150mph. No swaying. All stock bodywork.
  9. nismogod
    Deltona, FL
    sorry, the person that had said it before was in an EG so maybe that had some thin to do with it.
  10. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
    Check the alignment, sounds like the car has some toe.
  11. phunky.buddha
    My sedan is an EG8. It's definitely not the aerodynamic packaging of the car- it's most likely something loose in the suspension.
  12. swanny
    swanny Senior Member
    buck teeth and government checks, PA
    yeah there has to be something off, my 4 door gsr with stock suspension feels fine at 100.
  13. micah
    micah Senior Member
    you have a wing/spoiler?
    theoritically if your providing enough downforce to the rear end it could be lifting your front tires off the ground enough to cause you to float, would also prevent you from going much faster.
    of course that wouldnt explain the swaying while you decelerated
  14. phunky.buddha
    :lmao: :blink: :lmao: :lmao:
    I seriously doubt it, especially with any of the OEM or aftermarket wings out there that bolt onto a Civic. You would have to be generating a LOT of force at the very rear of the car to have enough leverage to pull the front end up enough to start losing traction.
    If the wing is about oh, 36 inches behind rear hub (pivot point) and the rear wheels are about 103 inches behind the front (pivot point), assuming we have no lift or downforce at the front to worry about at speed, and assuming that the weight distribution is 65% up front (pretty good estimate I think) on a 2500 pound car, this is what comes up:
    1625 pounds on front axle, simple calculation (at rest)
    Assuming I have a pretty close estimate of the rear overhang (dunno) and the wheelbase (pretty damn sure), then the leverage multiplier for force at the rear of the car to overcome force at the front wheels would be 2.86.
    You would need 4649 pounds of force generated by the rear spoiler in order to lift the front wheels off the ground. Of course, significantly less force would be required to cause the front wheels to start losing traction, but then you assume that your car is actually stiff enough to allow small amounts of force in the rear to lift the front tires. If you've ever put the front end of your car on jack stands, supporting it from the jack points, you've seen how much the flex the Civic chassis has from front to rear.
    Even if you were able to generate even 100 pounds of lift at the front of the car, assuming perfect force transfer from the spoiler to the front, the flex of the car from front to rear would pretty much negate any significant lift at the front from the spoiler pressing down on the trunk. If you were able to generate enough force to really do something up front, you'd probably punch the spoiler straight through the trunk lid.
  15. civicious
    Houston, TX
    all those numbers make my head hurt. long story short...its not because of your mad tyte 2 fats 2 furious wing.
  16. phunky.buddha
    There are only eight numbers in all that mess. It's easy math. :p :lol:
  17. micah
    micah Senior Member
    lol well was just a guess, i know a buddy put a wing on his sol and ever since then he cant break 120 ( its a built b16 )
    and another friend had an iroc that just after 100 mph, the back wheels started hovering ( something about him not having enough downforce on the rear ) and he would lose traction
    :D
  18. phunky.buddha
    Yeah- that would be the entire car acting as a lifting body, not just a wing. The wing on the Sol could easily generate enough drag to limit top speed though.
  19. liquid00meth
    liquid00meth Senior Member
    Laconia, NH
    check to make sure one of your calipers isn't sticking. That could be causing a constant uneven force, and maybe it's amplified by a loose tie rod or something similar.
  20. cycloneb18c3
    cycloneb18c3 Senior Member
    New Jersey
    yea, get an alignment(you may need tie rod ends, and or brakes), then:
    sway bars
    strut tower bars
    rear lower tie bar
    ive done 160 in a 93 civic hatch with a type R and it held steady with this stuff and neuspeed springs and koni shocks.
    my brother had my car to 145 and it is steady
    The only thing I have problems with on my car is:
    going over 100mph the windshield wipers slide up the windshield. I have yet to figure this one out.
