abrevation what are the words???
Discussion in 'ECU's, Electronics, and Tuning' started by Dark91zc, Jun 11, 2005.
  1. Dark91zc
    Dark91zc Senior Member
    Corona,CA
    what are these abrevations
    they are for obd-1 ecu
    PO2H
    VTS
    LG1
    PG1
    IGP1
    IACV
    PCS
    FLR
    ACC
    MIL
    ALTC
    ICM
    LG2
    PG2
    ICP2
    FANC
    CKPP
    TDCP
    CYPP
    ACS
    STS
    SCS
    VBU
    CKPM
    TDCM
    CYPM
    VTM
    PSW
    ALTF
    VSS
    TPS
    ECT
    MAP
    VCC1
    BKSM
    KS
    PO2S
    IAT
    VCC2
    SG2
    SG1
    EL
  2. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    That's all I know off the top of my head.
    You're messing around with a pinout, aren't you. Why?
  3. Dark91zc
    Corona,CA
    This is what i have so far if anyone can help me i would appecaite it. thanks civic :)
    OBD 0 – 1 Jumper harness
    Pinout '90-1 HF/Si Obd-0 OBD1 Color Function
    A1 No.1 INJ Injector 1 A01 Brown
    A2 GRD w/A4 to Main Relay
    A3 No.2 INJ Injector 2 A03 Red
    A4 GRD w/A2 to Main Relay VTS A04 Orange/White to Green/Yellow to Green/White Spool Soleniod
    A5 No.3 INJ Injector 3 A05 Light Blue
    A6 Purge Cut-Off Solenoid Valve (HF Only) PCS A20 Red
    A7 No.4 INJ Injector 4 A02 Yellow
    A8 Lock-up Control Solenoid Valve
    A9 -
    A10 EGR Valve (HF Only)
    A11 EACV w/A17 IACV A09 Green/White
    A12 Main Relay w/A14 FLR A07 Green/Yellow
    A13 Main Relay w/A15 STS B09 Blue/White
    A14 Main Relay w/A12 IGP1 A25 Yellow/Black
    A15 Main Relay w/A13
    A16 GRD w/A18
    A17 -
    A18 GRD w/A16
    B1 -
    B2 -
    B3 Fast Idle Valve
    B4 Radiator Fan Relay FANC A12 Yellow/Green
    B5 Alternator ALTC A16 White/Yellow
    B6 Check Engine Light MIL A13 Green/Orange
    B7 A/C Switch w/B8
    B8 A/C Switch w/B7
    B9 -
    B10 Crank Angle Sensor CKPP B15 Blue/Green
    B11 Clutch Switch (HF Only)
    B12 Crank Angle Sensor CKPM B16 Blue/Yellow
    B13 No.2 Fuse (10A)
    B14 Alternator ALTF D09 Pink
    B15 Igniter Unit w/B17
    B16 Speed Sensor VSS B10 Yellow/Blue
    B17 Igniter Unit w/B15
    B18 -
    B19 ELD EL D10 Green/Red
    B20 Ign. Timing Adj. Connector
    C1 Cylinder Position Sensor CYPP B11 Orange
    C2 Cylinder Position Sensor CYPM B12 White
    C3 TDC Sensor TDCP B13 Orange/Blue
    C4 TDC Sensor TDCM B14 White/Blue
    C5 TA Sensor IAT D15 Red/Yellow
    C6 TW Sensor ECT D13 Red/White
    C7 Throttle Angle Sensor SG2 D22 Green/White
    C8 -
    C9 PA Sensor
    C10 Brake and Reverse Light Switch (HF Only)
    C11 MAP Sensor MAP D17 Pink/White
    C12 Throttle Angle Sensor TPS D11 Pink/Black
    C13 Throttle Angle Sensor VCC2 D20 Yellow/White
    C14 MAP Sensor SG1 D21 Green/Blue
    C15 MAP Sensor VCC1 D19 Yellow/Green
    C16 O2 Sensor A
  4. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Dar91, he wants the OBD I ones, while some are the same, alot are not.
    If you're messing with a lot of wires, go buy the Helms, you'll thank yourself.
  5. Dark91zc
    Corona,CA
    i have a haynes book for both but the 84-91 haynes book doesnot have and ecu diagrams in it where the 92-95 does and if you look at what i posted above the a-c on the left side is obd-0 and then in the middle is obd-1 then wire color. i am wondering how close i am
  6. xj0hnx
    C.C.TX.
    :huh: huh?
    anyway, http://www.hondaswap.com/forums/index.php?showtopic=29360
    OBD I calls the third plug D, not C.
    Tell me whch ones you want specifically, and I'll post them, but to get motivated to type the whole list is not likely going to happen :( <---lazy)
  7. xj0hnx
    C.C.TX.
    Ahhh, ok, I see what you did here. let me compare them....
  8. Dark91zc
    Corona,CA
    i have been doing the rewrite on word and i want to know if i have everything right now??
  9. xj0hnx
    C.C.TX.
    I editted your post to reflect some of the differences between the OBD 0 and OBD I ( what's in bold)
    If you need more, let me know.
  10. Dark91zc
    Corona,CA
    thanks bro :) props to the mod :)
  11. Dark91zc
    Corona,CA
    [​IMG] i have a extra obd-0 ecu and i am going to desodler it from the board and solder obd-1 ecu plug wires to this [​IMG] i am making something that looks like this [​IMG]
    this is for the people that are lost :)
  12. brian11to1
    brian11to1 Senior Member
  13. bhaskergm
    bhaskergm New Member
  14. whiterabbit06
    Crestview, Fl
    Here you go.
  15. BrutalB83
    Rochester Hills, MI
    Holy dead thread resurrection Batman! :eek:
  16. Aleaf.CRX
    Aleaf.CRX Hates Cunts!
  17. whiterabbit06
    Crestview, Fl
    I just thought that if anyone was still wondering I would post up what they all mean since it was brought back.
