Get it fixed and it will go away! Haven't you heard of common sence?
The ABS light will not make your ECU throw a code. The ABS light being on means that it is not functioning. Have you replaced anything axle/hub wise recently? Check related fuses, and as long as your axles are the right ones (with the ABS rings) you more than likely have a bad wheel speed sensor, cause you have a 90s accord and the wheel speed sensors go bad in them.
