abs ??
boostedf22
dis is why im not
Should I do away with it or keep it . Would it make that much of a difference on weight . I know every lb. counts . Would it hurt me in lond run ??
Personally I never feel the abs in use.
I don't have abs on either civic I have. There have been a couple of times on the street where I feel that it might have helped, but I'm fine without it. If this car was going to be used at the track, take it off if you want. If it is a daily driver, I would leave it on there. The benefit from weight loss you would gain wouldn't be worth it if it even helped you one time.
it will be the DD that sees the track every weekend. As hard as I push the car . I have never felt the abs kick in . Hell the wheels will lock up now . No abs light though . I think I am going to do away with it . Cleaner engine bay FTW.
Does anyone know how abs will affect the car in auto-cross. W/ or without.
