AC compressor getting no power
Discussion in 'Civic and CRX - EF' started by fixed4 life, Jul 2, 2012.
  1. fixed4 life
    fixed4 life New Member
    Haltom City TX
    I have a 90 Si, my ac compressor is not getting any power. I have hard wired it and it will kick on. Is there a relay or fuse somewhere that would cause it not to work? Could the ac button on the climate control be bad? Any help would be appriciated. I live in TX and its HOT!
  2. dc4dude
    dc4dude Member
    chicago, il
    short the switch terminal on the high side... see if that is getting power... sometimes the switch will go bad... also, if you dont have enough freon (because of a leak) it will also not go on... many different variables with the a/c dude.
  3. fixed4 life
    Haltom City TX
    Thanks, i was messing with it earlier and it needed freon. It started working as soon as i filled it.
  4. dc4dude
    dc4dude Member
    chicago, il
    So that means you have a leak somewhere... Its is a sealed system, just like the brake system...
