AC Turns on out of no where while driving?
IIpower
I have a 00 Gsr and the AC keeps truning on out of nowhere. I will be sitting at a light and it will just turn on. It sounds as if it turns on only when the Radiotor fans turn on after the Radiator relay kicks in. Any reason as to why its doing this? How can I stop it without having to disconnect my ac?
it could be possible that the grounding on the ac relay is using the same grounding from your fan relay located in the fuse box in your engine bay., if your grounding is weak, it will drain power from another source on the same grounding wire activating both. another example of this is next to the headlights, u disconnect the 5 black wire connector from the chassie and both your headlights (integra) will turnon, thats your low beam and your high beam, while your high beam is switched off.
