acceptable camber kit?!
Discussion in 'Wheels / Suspension / Tires / Brakes' started by bdogggut34, Jul 14, 2004.
  1. bdogggut34
    bdogggut34 Senior Member
    What have people done to correct their camber?? Is the Progress kit here for the front and rear a reliable one to use??
    http://216.82.69.117/detail.asp?PRODUCT_ID=53-1003-H
    Or does anyone have other suggestions?? I was looking at the Skunk2 for the front but thats already about $159.
  2. CRX-YEM
    Wallingford, CT
    what year, and model car are we talking. on most civics you can cheat in the rear and shim out with some washers to correct excessive negative camber.
    for the front the ingalls or progress kit will be just fine. also the skunk2 kit is a nice product for 92 (could be 95) and up civics.
  3. phunky.buddha
    Dallas / Fort Worth, TX
    I've used the Progress kit before- it's very strong and is very high quality. If you're short on cash, it's an excellent kit to go with. It's not adjustable like the Skunk2, SPC or Ingalls, but it's beefy as hell. You basically set it at one of two correction angles and bolt it up.
    By the way, only the lower right hand picture in their collage is the 92-95 kit. None of the others are 92-95 Civic kits.
  4. bdogggut34
    i'm getting the sportline springs to replace the Tsudo coilovers on there now and the shocks are Koni yellows, would i really need the adjustablility of the skunk2 one or will i be ok with the progress
    on a 92 si by the way
  5. Loco Honkey
    Loco Honkey Banned
    I had Sportlines on my '93 Si, and the ONLY thing you'll have to do is set the front toe. That's it. Trust me.
