accidental jump, car wont start!!
Discussion in 'HYBRID -> EG-EK / DC' started by h22poweredgsr, Nov 1, 2003.
  1. h22poweredgsr
    h22poweredgsr Member
    i got a cel and decided i was gonna jump the wires. i reach under the drivers side and reach for the clip. i guess i grabbed the wrong one. it is green and has like 5 wires goin into it. i jumped them and saw a spark. so i decided to start my car and it wont start. it tries to turn over but wont start. is my battery dead?? what is that harness? hellppppp
  2. rudeludenotmeanthough
    rudeludenotmeanthough Senior Member
    sad...
  3. h22poweredgsr
    im gonna hope that mah battery is jus outta juice...
  4. MXDesa
    MXDesa Senior Member
    Queens, New York
    If your battery was outta juice it wouldn't turn over, after a while nothing would happen. I hope you didn't fry your ECU
  5. h22poweredgsr
    what do u mean after awhile nothing would happen?? could i reset my ecu?? and would this help. any idea what that clip i jumped was??
  6. h22poweredgsr
    the wires are black, yellow/blue, orange, yellow, and i dont remember the last one. it is under the steering column and is hanging there. not sure if its suppose to or not
  7. Revolveu2
    Revolveu2 Junior Member
    Carol Stream, IL
    Have you checked all your fuses, to see if you blew any? That would be the FIRST thing to do.
    Other than that, check your relays, amke sure they are woring. Check for fuel, and spark in the engine.
    Hope you didn't fry your ECU, and no, you can't "reset" it.
  8. h22poweredgsr
    yea i checked all my fuses. i found out that what i jumped was the abs harness going into the little module under the steering column. it was hanging loose i guess. its a green connector. i dont have a voltomter so i cant check for relays yet.
  9. jeffsciv23
    jeffsciv23 Senior Member
    Wa
    you were just trying to check your CEL? what are you getting now? (dont jump the same one to find out, try the two wire service plug next time). hope you didn't fry your ECU.
    note for next time: always check before you go jumping wires.
  10. SixtySecondAssassin
    Austin, TX
    your lucky you didnt blow your airbag.
  11. jeffsciv23
    Wa
    sorry but i would have died laughing if the topic said "accidental jump, hit with airbag".
  12. swanny
    swanny Senior Member
    buck teeth and government checks, PA
    lmao :lol:
