ACCORD 6 CYL INTO CRX?
Discussion in 'HYBRID -> BA-BB /CA-CD' started by AZEROTH, Jan 1, 2003.
  1. AZEROTH
    AZEROTH Junior Member
    Im not sure if it will fit but thats what i want to do with my CRX, i dont drive it cause its a night project of mine, i need a sick swap like this, "theres no substitute for cubic inches."
  2. Silver94Teg
    Silver94Teg Member
    The j30A1 engine in the accord v6 is just about the last thing you want to swap into your ride. It's plagued by a castrated econo-cam that only lifts HALF an intake valve below 3500 rpm's, and is therefore majorly lacking in low end power like other 6 cylinders. If you're going to be swapping a v6 in there i'd look at acura's j32a2 in the cl-s, it is just like the j30, but with no crappy cams. Check this site out, real helpful people:
    www.accordv6.com
    The engine is pretty big anyways, i doubt it will fit into a cr-x. :)
  3. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    you will have major mounting issues even if it does fit (which i think it wont)
  4. chet
    chet Senior Member
    st petersburg, florida
    get a b20 block, have it resleeved and make 250whp with a vtec head.
    obviously its not the easiest swap, but if built correctly these setups are monsters.
  5. AZEROTH
    silver94teg thanks for the input ill check out that site.
  6. h22freshman
    h22freshman Senior Member
    Drop that shit...drop a h22 in there...or if ur going for boost drop an h23 in there and u will have to suffer a while with mediocre power...and then slap the turbo on...or even a supercharger
  7. prawjEKt Cx
    prawjEKt Cx Senior Member
    upstate NY
    i'm with him :werd:
  8. HondaISLife
    HondaISLife Junior Member
    That is still one huge fucking motor to be putting in a CRX, lets hope that this guy doesn't want to go around curves at any high amount of speed
  9. Havok
    Havok Senior Member
    Florida
    I think it will be sweet to see a rex with the turning radius of an 84 Impala for a change :)
  10. cxjon
    cxjon Senior Member
    man+k+toe
    lol thats funny shit!
