accord automatic to manual?
Discussion in 'HYBRID -> BA-BB /CA-CD' started by holycost, Aug 29, 2005.
  1. holycost
    holycost Junior Member
    i've looked around and can't find a list of required parts for a 6th gen accord for a automatic to manual conversion list of parts i will need, i just know i need either a 6th gen manual tranny or 92 and up prelude tranny, thank you all
    o and i'm swapping a 2001 4dr accord 2.3L ex to manual
  2. 416
    416 Junior Member
    well there's the basics. You need the pedal box, the instrument panel, the clutch master, the clutch slave, the lines, the wiring harness ( for the starter sw), the ecu has to be changed for a 5spd ecu and the older tranny may not have all the connections that the computer is looking for.....but I may be wrong about that.
  3. cardigit
    cardigit Junior Member
  4. cardigit
    Shift cables, Shifter assy, clutch and brake pedal assy., Shift knob and
    boot, Clutch master and slave cyl's, clutch line, tranny of your choice (
    F22, F23, H23, H22) Pass. side tranny mount, Driver side half shaft and
    intermediat shaft, 5spd starter for the yr and model tranny. Misc bolts and
    hard ware for all of this. Clutch assy, flywheel. I'm sure there might be
    something I forgot but this is most of it. Good luck
  5. LOS222
    LOS222 Member
    Does anybody have the instructions for the 94-97 accord swap?
