Accord Brake Upgrade
Discussion in 'Wheels / Suspension / Tires / Brakes' started by reckedracing, Jun 9, 2005.
  1. reckedracing
    reckedracing TTIWWOP VIP
    NY
    SO my good friend has his 93 accord with an h22 swap...
    he's looking for a fairly cheap brake upgrade for the front rotors...
    rear too, but first the fronts...
    i was wondering if anyone knows if the 92-95 preludes have larger front rotors than the 90-93 accords?
    i was also wondering what the opinion of Big brake kitsare, these consits of a larger mounting bracket, stock calipers, and larger rotors...
    the big brake kits go form approx 10 inch, to a 12 inch rotor...
    i can see better braking due to more leverage, and also more surface area on the disc to disapate heat...
    he definately can not afford a full brake setup...
    its either stock replacement, prelude swap if the rotors are larger, or this "big brake kit"...
    let me know what you think
  2. reckedracing
    NY
    so here's some more info...
    Accord OEM = 10.24" rotor
    Accord "Big Brake" = 12.15" rotor
    Prelude SI OEM = 10.21"
    Prelude VTEC OEM = 11.09"
    Prelude VTEC "Big Brake" = 12.19"
    so if the "Big Brake Kit" is just as i suspect someone will say, then i'm gonna look into upgrading to prelude vtec rotors...
  3. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    Why not just get some upgraded pads and stainless lines with some good fluid? If he really wants new rotors, just go with some normal-sized Brembo blanks. Chances are, he's going to be limited by the traction of his tires before he needs all that stopping power of 2 inch-larger rotors.
  4. reckedracing
    NY
    My personal advice to him was brembo blanks and some aggressive pads...
    But he asked if I would research the matter...
    4 door SE's are damn heavy cars, especially with full leather and 18's etc...
    stock rotors are fine for the F22's but the H22 tends to put more stress on the braking system...
    i think i would def not go with the "big brake upgrade", but i am interested in getting the rotors/calipers that came on the VTEC lude's if the price was reasonable...
  5. dohcvtec_accord
    The left lane
    Will they fit onto the Accord hubs? Will they fit under the wheels?
    EDIT: VTEC Preludes (and maybe all the 4th gens?) were 5-lug. 4th-gen Accords were 4-lug. Doh!
  6. driver1
    driver1 Senior Member
    4th gen preludes, were all 4x114.3 identical to the accord lug pattern
  7. Battle Pope
    Battle Pope New Member
    Southern Oregon Coast
    All 4th gens (including the VTEC) were 4x114.3 if I'm not mistaken
    in '97 they changed to 5x114.3 (same as Accord V6)
  8. driver1
    kinda like this here.....and/or what i just said :p
  9. 88bluehf
    88bluehf Senior Member
    Denton,TX
    couldnt you just run the prelude vtec rotors and calipers? your current calipers should be a 17cl14vn variety, you want 17cl15vn calipers...they came on vigors,accord wagons,cl,tl accord v6, type r integra,prelude vtec...etc.
  10. dohcvtec_accord
    The left lane
    Huh. Shows how much I know. :p
  11. reckedracing
    NY
    did you read the thread?
    i was trying to find out if they do fit for sure...
    the theory was already laid down, just looking for someone to confirm it...
    do you know the diffrence between the 14 and 15 variety?
    so accord wagon should have the 11" brakes as well then?
  12. 88bluehf
    Denton,TX
    if your knuckles have 14's on there now then 15's will with and allow you to have 11in brakes
