Accord/Prelude Turbo Kit For Sale
Turbo&Auto
Nick Go FAST!!
Selling my DSM Hybrid Turbo setup still.....It really needs to go now!
Whats included:
*DSM Manifold, already modified to fit the F22/H23 head, ported to 6cm for the 16G turbo
*TD05 BIG 16G Ported turbo w/internal wastegate
*Stainless Steel oulet elbow
*Stainless Steel open wastegate dump with 2.5" collector
*Ported DSM O2 housing (extra piece or for a more stealth sound)
*2.5" Stainless Steel Downpipe, cut under the oil pan!
*2" Heat wrapped pipe to the FMIC
*2.5" Piping from FMIC to the TB
*Same side In/Out Polished FMIC
*3" Custom Heat wrapped CAI
*Water cooling lines and "T's"
*Oil Filter sandwhich adapter with AN4 fitting
*AN4 fitting on inlet of turbo and 3/8"NPT->AN-8 for Oil Drain
*Greddy BOV (not a Knockoff)
*TurboXS MBC
*All the silicone couplers needed to connect it to the car
*Crome Map, tuned to 17psi with 550cc Injectors and a 3 Bar MAP sensor
Parts you will need:
*AN4 Oil Feed Line
*AN8 Oil Drain
*550cc injectors (or other if you can tune Crome)
*3 bar MAP sensor (or other if you can tune Crome)
I apologize if I left something out, my mind is a lil cluttered at the moment :) The stock rad can and is being used now. I just bought 2 cheap electric fans and mounted them to the outside. Car has YET to overheat!!!
Asking $1400 shipped for everything, OBO. MUST SELL!!!!!
Edit: I will even throw in that chrome valve cover for the 1400!!! :D
