accord rear hub bearing, help please
Discussion in 'Accord' started by Sleeper00, Mar 25, 2009.
  1. Sleeper00
    Sleeper00 New Member
    FLORIDA
    i have 92 accord lx with ex rear disk brake swap, my rear hub bearing went bad, can i just change the bearing and keep the factory hub?? if yes where can i buy just the bearing? or is it better to change the whole hub assembly? and where i can buy the hub assembly?? cos i m having problem finding it online, the 1 i found is for drum brake. thank you.
  2. Hondadude141
    TX
    You want/have to change the whole hub assembly I believe, and check your local parts stores or call your local honda dealership
  3. 92stoccord
    92stoccord Big Member VIP
    Salem, Ohio
    I believe he is right.
  4. Blakwolf9666
    Blakwolf9666 Member
    Miami
    you would have to find the bearing/hub assembly for the ex car you took the brakes off of since its a conversion
