ACL bearings
Discussion in 'Engine Building' started by hmtcrxsir, Jun 22, 2005.
  1. hmtcrxsir
    hmtcrxsir Member
    Just wanted to know if ACL bearings are one size fit all? Or do they have different size too?
  2. abdelsol
    abdelsol Member
    I would not use anything but OEM bearings and maintain a .0015 clearance. One size cannot fit all....
  3. 97CTR
    97CTR Senior Member
    ACL's are the equivalent to a Honda green bearing. So they are indeed one size.
  4. pissedoffsol
  5. abdelsol
    abdelsol Member
    Okay give..... I have read alot about only use OEM. and somewhere, don't remember where that Nascar alters the main to fit Honda OEM.....
    So what do you know? Give.....:)
  6. pissedoffsol
    all the top honda engine builders use ACL, and so do I.
    wildbill rebuilt that all-motor LS with an acl bearing kit.
    my gsr has one waiting to go on when i do the itr rods/pistons.
    you can get everything from rod bearings to thrust washers to mains for about 100 bucks.
  7. GSRCRXsi
    MD
    but what about clearances? everything should be the same clearance. if you just put all the same size, they wont all be right. unless acl offers different sizes, but from everything ive read its all one size, and about the size of a green bearing.
  8. Speedracer228
    Speedracer228 ......
    :werd:
  9. MXDesa
    MXDesa Senior Member
    Queens, New York
    ACL bearings are available in standard, oversized, undersized etc... If ur wondering if they come in different sizes in packs, then no they dont. If u require different size bearings for each rod, than its time to machine the crank and use a over sized bearing. They hold up very well, that Talon in my sig uses ACL bearings.
  10. phunky.buddha
    Dallas / Fort Worth, TX
    The clearances will all be "good enough" for the most part... but if you want to nail them dead-on, OEM is the way to go.
  11. abdelsol
    abdelsol Member
    "good Enough".... I am :walk: away from that. No agreement with that, sorry.
    "nail them"....... :yes:
  12. 97CTR
    97CTR Senior Member
    If you want it done to the letter then yes, OEM and plastigage is the way to go. I used one color bearing to measure the clearances I had with that bearing and calculated the differences in thicknesses of different colored bearings to get the proper clearances. A search should yield you the thicknesses of each color for oem bearings.
  13. hmtcrxsir
    hmtcrxsir Member
    well since i spun a bearing last month. I decided to change all the bearings instead of just changing the bearings that needed to be changed. That way i know that all the bearings are new and dont have to worry about them. BTW, this is just my daily driver.
    After disassembling everything, I looked at the stamping on the block and the numbers on the crank and found that the engine came from the factory with the following main bearings.
    Journal #1: B3 = Green (crank pulley side)
    Journal #2: A2 = Pink
    Journal #3: B4 = Brown
    Journal #4: B2 = Yellow
    Journal #5: C3 = Brown
    Using the other set of crank stampings and the numbers of the rods, I can see that my engine came with the following rod bearings from the factor.
    Rod #1: B4 = Brown
    Rod #2: D4 = Blue
    Rod #3: B4 = Brown
    Rod #4: B3 = Green
    I am not sure what to do about the ACL bearings because my rod bearings are 3 different colors and my main bearings are 4 different colors. Getting Honda bearings would be easy but expensive. And i'm on a budget right now. So you guys think the "one size fit all" will fit just right?
  14. hmtcrxsir
    hmtcrxsir Member
    BTW, can someone quickly go over how to use a plastigage. This is my first time measuring bearing clearance. And Yes, I do want to learn and will not let any other professional do this.
    Wasnt sure if i should use the red plastigage or the green one?
  15. 94CivicSlow
    94CivicSlow Senior Member
    B0ST0N
    Id buy the one that spun from honda, and double check the clearances on the rest. No sense in replacing what isnt broken. No, one size doesnt fit all. I used TOPLINE bearings in my motor build, the machine shop said they were perfect
  16. hmtcrxsir
    hmtcrxsir Member
    well i think i have to change the crank anyways because its already scratch due to bearing failure. So I dont think i can use the same bearings on a whole different crank in the same block. Unless it has the same specs. Which i highly doubt is the same. So thats the reason why im planning to replace every bearing there is.
  17. phunky.buddha
    Get the new crank first, then find out what you're supposed to need. Any crank polishing will change the clearances, so be careful.
  18. hmtcrxsir
    hmtcrxsir Member
    I guess i'll go with ACL if no one complains about them.
    :D
    So do i measure the top bearings and the bottom ones? Or just the bottom one? ????
  19. abdelsol
    abdelsol Member
    Depending on the the depth of the scratch and the size of you mains you may be able to save your crank.
    What are you trying to do with this build? make some power? just get it on the road? have the engine last for a little time or a long time?
    I don't want to poop in your cheerio's, but the majority of posts indicate proper clearances are needed. are you looking for approval to just slap it together?
  20. hmtcrxsir
    hmtcrxsir Member
    well you can say i just need the motor running because i have smog check in a month or so. So i need to get this car running. Well its a 95 civic ex and its only my daily commuter.
    and yes i got another crank from another D16z6.
