ACL or OEM bearings for D16a6?
Discussion in 'Engine Building' started by 89' Project Civic, May 7, 2009.
  1. 89' Project Civic
    89' Project Civic d16a6/d16y8 "mini-me"
    St. Catharines, Ontario, Canada
    I'm wondering if I should use ACL or OEM main bearings on my Stock D16a6 rebuild. Any advice will be greatly appreciated.
  2. red91efhatch
    red91efhatch New Member
    Albuquerque
    OEM bearings are good, ACL are also good, lot's of people use ACL race bearings when rebuilding. I used standard ACL bearings on all my builds and they've done just fine in all cases.
  3. 89' Project Civic
  4. efhondakid
    Akron-Canton, Ohio
    Use OEM! Honda uses a nitrate coating on the crank and bearing surfaces, hopefully you didnt have the crank turned. Do I have to get out my "ACL carnage" pics?
  5. 89' Project Civic
    What do you mean by "crank turned"?. No, I already saw them which inspired me to post up this thread to see other people's experiences, but I will take your advice considering your experience wasn't so good. I will get the OEM bearings but they cost $136 plus taxes for just the rod bearings. That isn't including main bearings!.
  6. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    Get ACL, they're all "Green"-spec. Install them, check all clearances; disassemble, and replace bearings that are out of spec with Honda bearing. Way cheaper to go this route and ACL bearings work just fine.
  7. red91efhatch
    Albuquerque
    ACL FTW! listen to the guy who rebuilds Honda Engines on a weekly basis with 0 that's right Zero customer bring backs this far.
  8. efhondakid
    Akron-Canton, Ohio
    Well I dont like ACLs.
  9. K2e2vin
    Raleigh, NC
    As stated before, it's all in the clearance. You can't just throw in ACL's and call it a day; you have to check the clearances. It's the oil that keeps the rod from touching the bearing/journal.
  10. 89' Project Civic
    I went to drop my stuff off at the machine shop, and I got talking with my machinist. He asked me if I was still thinking OEM, then suggested some Clevite bearings for my build. He knows his shit obviously so I told him to go ahead and order me some. I will take your suggestions and check for clearance issues and if any are out of spec replace with OEM. Is mixing bearings an alright thing to do?. Thanks for the input so far, guys!.
  11. K2e2vin
    Raleigh, NC
    Clevite makes very nice bearings; but didn't know they had anything for the SOHC D-series.
    Yes, it is perfectly OK to mix bearings; it's just imperative that you have the correct clearance. Clearance is everything when it comes to the lubrication system.
  12. 89' Project Civic
    That is really re-assuring to know they are good quality bearings. Although I am doing a stock rebuild I still want the engine to goto 400-500k, but by then I will have my B20:), I hope:p.
  13. K2e2vin
    Raleigh, NC
    As long as you maintain your car(not just oil changes, but replacing "wear" parts for given intervals), it'll definitely be able to reach your goals. Some guy hit like 1200000 miles(yes, 1.2 million) on his 92-95 Civic coupe; and it was running perfectly fine when he sold it.
  14. phunky.buddha
    Dallas / Fort Worth, TX
    I usually hear Clevite in association with domestic engines.
    I've always used OEM bearings on my builds, but I've considered using ACLs for my D series. I had to have my clearances perfect, so I always had my stuff put together with nothing but Honda bearings. OEM has the widest selection. Most of the time though, the ACLs will give you clearances within spec without having to get too many replacement pieces. If you want to be a dork and have all your clearances match to the .0001, then you'll have to go OEM. :D
  15. 89' Project Civic
    Haha, I will be willing to be that dork because I want it done right the first time:p. I don't know if he knows that the company even carries them for the D-Series engine. He has done work to a lot of motors in his time I'm sure. When I was there I saw a block with only 3cylinders. Is that normal?.
  16. K2e2vin
    Raleigh, NC
    Probably Geo Metro engine or something.
    I don't think the Plastiguages are thick enough to measure without a bearing; so you'd still need ACLs or something to work from.
  17. phunky.buddha
    It's not a question of doing it right- the ACLs will still be "right", but the Honda OEMs just enable to you to be an even higher degree of "right" if you're willing to spend the cash to keep buying bearings until you get the perfect fit. ACL built engines last just as long as OEM bearing engines.
    Geo Metro, Suzuki Swift, Honda Insight, smart fortwo, any number of oddball European cars or Japanese kei cars (Saab Sonnet I think)- loads of 3 cylinder engines out there. I saw a nice inline-3 in a monster build once in Houston- it was an 18 liter engine.
    You definitely need the bearings to Platigage the engine.
  18. 89' Project Civic
    Yeah, that's for sure. Another question though, when I get this block back will I have to buy my own measuring tools to do the job?. The machinist says he is going to measure everything and telling from his tone of voice and what he was saying, I think he will have all the measurements done for me to just torque/plastiguage everything to specs. and get it going. Is this presumption correct or do I still need the measuring tools?.
  19. phunky.buddha
    That's between you and how much you trust your machinist.
  20. 89' Project Civic
    Thanks for clearifying that. I trust him a lot due to his reputation.
