Acura Integra Full List Of Components
Discussion in 'Engine Building' started by YangpaNemsay, May 21, 2003.
Thread Status:
Not open for further replies.
  1. YangpaNemsay
    YangpaNemsay Senior Member
    Okinawa, Japan
    The following is a list of components of the engine, suspension, brakes, forced induction, etc. of known aftermaket companies that make parts for the DC2 Integra, if there are any more aftermarket manufacturers or components to the engine/suspension/brakes/etc. that i left out please feel free to add them in, The Asterisk (*) indicates either that i know that there were more manufacterers but didn't know them at the time or that i have no clue what to use. I'm currently a junior in high school and plan to make an Integra Go Car and an Integra Show Car. Thanks for you input.
    Engine
    Intake (AEM, Mugen, Spoon)
    Exhaust (Fujitsubo)
    Catalytic Converter (*)
    Intake Manifold (JG Edelbrock, *)
    Pistons (JE, Low Compression, Wiseco, Arias)
    Oil Pump (ProDrive, *)
    Cams (TODA, SKUNK2, AEM, *)
    Camshafts (Crower, HKS, Web, *)
    Rods (Manley, Crower, Eagle Rods, *)
    Timing Belt (*)
    Timing Chain (*)
    Valve Springs, Valves & Valve Seats Crower, Ferrea, TurboTrix, Web, Spoon, *)
    Fuel Rail (Venom, AEM, HKS, *)
    Fuel Injectors (RC Road/Race, *)
    Spark Plugs (Denso Iridium)
    Oil Cooler (*)
    Sleeves (Golden Eagle Block Guard?, *)
    Fuel Pump (Walbro, Paxton, SX, Denso)
    Pulleys (*)
    High Flow Fuel Filter (*)
    Crank (Spoon, *)
    Ignition (*)
    Ground Systems (Sun Auto, *)
    Oxygen Sensors (300zx?, *)
    Suspension/ Handling
    Tires (Hoosier RS303, Nitto 555R)
    Wheels (Volk TE37, CE28, Axis Mag-Lites, *)
    Axles (*)
    Coilovers (Tein N1, SS, *)
    Shocks (*)
    Urethane Bushings (Energy Suspension, *)
    F/R Strut Tower Bars (Spoon, Mugen)
    Control Arms (*)
    Strut Brace
    Lower F/R Tie Bars (Spoon, *)
    Chassis Brace (*)
    Roll Cage (*)
    Transmission
    Clutch (ACT, Clutchmasters, JWT, *)
    Flywheel (ZEX, Clutchmasters, *)
    Driveshaft[carbon fiber] (*)
    Final Drive (Spoon)
    Hardened 1st Gear (Spoon)
    Steel Shift Forks (Custom made, Team Rip Engineering, *)
    Double Synchros 3rd 4th 5th (Custom made, Team Rip Engineering, *)
    Limited-Slip Differential (Cusco, Kaaz)
    ECU
    Fuel Management System (AEM, Greddy E-Manage, Hondata, *)
    Brakes
    Calipers (Brembo F350, Willwood, *)
    Rotors (Brembo, Willwood, Gran Turismo, *)
    Pads (Hawk HP, Project Mu)
    Brake Lines (Hyperfirm, Goodridge, Spoon, *)
    Brake Fluid (*)
    Forced Induction
    Nitrous Oxide (Venom)
    N-tercooler (NX)
    Turbocharger (Turbonetics, Blitz, Greddy/TRUST, Mitsu, Garrett, HKS)
    Intercooler (ARC, XS Engineering, Silvia Core, HKS, Spearco)
    B.O.V. (Greddy, Blitz, *)
    Intercooler Piping (*)
    Midpipe (*)
    Wastegate (Tial, HKS, *)
    Turbo Manifold (RevHard, DRAG)
    Oil lines (*)
    Boost Controller (HKS EVC 4, *)
    Body
    JDM Front End Conversion (*)
    Carbon Fiber Undercarriage (Spoon)
    Carbon Fiber Canards (*)
    Aero Mirrors (Spoon, Mugen)
    Lexan (*)
    Carbon Fiber Hood w/ scoop & vents (*)
    Safety
    Seats (BRIDE)
    Harness (Takata 5-point)
    Bulbs (Hella, PIAA, Chibie, Cibie, *)
    Fire Extinguisher
    Accessories
    Pedals (Razo, Momo, Sparco)
    Steering Wheel (Momo)
    Removable Steering Wheel Kit (*)
    Gauges (Apexi, Ractive, Eurolite, *)
    Short Throw Shifter (B&M, SOLO, *)
    Security
    Motion Alarm (*)
    Ignition Cut (*)
    Razor Blades (to protect against hot-wiring)
    Auto-loc
  2. YangpaNemsay
    Okinawa, Japan
    also forgot to mention, i plan to start the Integra Go Car and Integra Show Car in college.
  3. YangpaNemsay
    Okinawa, Japan
  4. YangpaNemsay
    Okinawa, Japan
    Brake Fluid (Motul RBF 600 Racing Brake Fluid)
    Fuel Pressure Regulator (AEM, Mugen)
    Grease (Mugen G-028M CV Joint Grease, Redline CV-2 Grease)
    Bushings (Mugen)
    Stabilizer (Mugen)
    Fan Switch (Mugen)
    Head Gasket (Spoon, Mugen, TODA)
    Radiator (Mugen)
    Thermostat (Mugen, Spoon)
    Valve Spring Set (Mugen)
    Pedals (Mugen)
    Hood Pins (Mugen)
    Battery (Optima, Spoon)
    Brake Line (Mugen, Stillen, Spoon)
    Cam Gears (TODA)
    Magnetic Drain Bolt Set (Spoon)
    Oil Pump Gear (TODA)
    Engine Oil (Redline)
    Transmission Oil (Redline)
    Brake Kit (StopTech)
    Calipers (Spoon)
    Break Pads (Spoon)
    Urethane Bushings (Spoon)
    Lower Arm Bushings (Spoon)
    Wheels (Spoon SW388)
    Carbon Fiber Bucket Seat (Spoon)
    Steering Wheel (Spoon)
    CF Hood (Spoon)
    Radiator (Spoon)
    Transmission Assembly (Spoon)
    LSD Plate Set (Spoon)
    Clutch Oil Pressure Line (Spoon)
    Shift Linkage Bush Kit (Spoon)
    Overhaul Engine Assembly (Spoon)
    Iridium Spark Plugs (Spoon)
  5. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
  6. phunky.buddha
    Dallas / Fort Worth, TX
    :withstupid:
  7. haccord141
    haccord141 Senior Member
    So Cali
    for any guages use autometer
  8. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    There are too many parts to list, do some looking. This is not a difficult car to find parts for.
Thread Status:
