Yes there are instructions here on HS just search I've posted them a cuple times. And YES it's worth it, you can also use aftermarket A6 Cams, delta does regrinds for $85.
Use a Z6 or Y8 IM and a B series TB when you do the MPFI swap and it will like the cam even more.
