poloboy4
ok i have both motors out side by side the motor would not start when i did the swap so i took it out again this time adding the crank sensor but on my 95 ex motor d16z6 it dose not have the bolts for the sensor nor the thing bolt hole for the crank sensor now look at the pics below my y8 block has the little things on the ( crank pulley?) or what ever that thing that sends the signal to the pulley is.
