adding vtec??
Discussion in 'Engine Building' started by hale97, Mar 25, 2009.
  1. hale97
    hale97 New Member
    Red Deer,Alberta
    i have a 97 integra non vtec 1.8L. i am looking for any info/advise/tip i can get about instaled a vtec head and how much work is involved. or if it is more worth while to find a vtec engine and just sway them out??
  2. MthaFuknGreen
    Lodi, CA
    :search:
  3. hale97
    hale97 New Member
    Red Deer,Alberta
    well that^^^^^ doesnt help.......... has anyone added vtec to a non vtec engine? i need to know how difficult it would be? or if its worth the hassel? or if its possible? any info would be great.
  4. tabKola
    tabKola New Member
    Tewksbury MA
    Many have added VTEC to a non-VTEC engine it's not that difficult, but it does require a bit of effort on your part. Do a search on an "LS VTEC" there are dozens of write ups on it and if you just read a couple of them you should be able to do it on your own.
  5. hale97
    hale97 New Member
    Red Deer,Alberta
    awesome thanks
  6. hale97
    hale97 New Member
    Red Deer,Alberta
    what head would you suggest using? or is one really better than the next??
  7. haao13
    haao13 New Member
    PA
  8. eg'sforlife
    eg'sforlife New Member
    29 stumps, CA
    hate to be captain douche bag but seriously the apocalypse wont come when you use the search function so its okay to use once and a while
  9. squeals
    squeals New Member
    Charlotte, NC
    i've always heard that the b16 head breathed better.
  10. sevenhillsbilly
    sevenhillsbilly New Member
    the search button will become your best friend.
  11. Slow&Delirious
    Slow&Delirious isn't fast or furious
    Boonville NC
    there are tons of guys who have done LS swaps, you arent going to get as much power out of just a GSR head swap as opposed to getting the entire GSR engine
  12. hale97
    hale97 New Member
    Red Deer,Alberta
    i figured that, but from what i understand it the ls block is supposed to be better to turbo. and being on a bit of a tight budget i was thinking that would be a solid way to go(with the gsr head). or do u think a b16 head would be better? thanks
  13. whiterabbit06
    Crestview, Fl
  14. Matts96HB
    Matts96HB . Moderator VIP
    Wrong. GSR and B16 flow ratings are nearly identical if I remember correctly.
  15. integraslut78
    integraslut78 Stylus DJ Extraordinaire
    KiLLa kALi
    I think you may be thinking about the IM.
  16. 152madwhp
    152madwhp New Member
    you sir are a tard...more displacement equals more power:facepalm:
  17. 152madwhp
    b16 head flows better at certain points than b18 and vice versa
  18. integraslut78
    KiLLa kALi
    Your posts make my head hurt. First off he was right you can't get as much power out of a LS/Vtec that you can get from a full GSR.
    Next again your posts make my head hurt. The flow charts between the heads are almost the same, you're thinking of the B16 intake manifold that flows better than the GSR IM.
    hale97 please don't listen to this NOOB he and his 152whp have no idea what they're talking about.
  19. tomzauto
    tomzauto New Member
    Lebanon, PA
    haha
