adjust headlights
blewup91rex
Does anyone have any idea on how to adjust the low beam on a 94 integra
on the headlight housing there are 2 adjustment knobs, round metal, there is a space to stick a tool down to engage the knobs, adjust to your needs.
if you do not have the proper too to do the job, you can use a good #2 phillips screwdriver, but try not to force it to work, otherwise you might break the adjustemt and then you will have to get a new headlight
