Adjusting (Cable) clutch on 91 Civic si
Discussion in 'General Tech and Maintenance' started by vic42, Nov 17, 2005.
  1. vic42
    vic42 Junior Member
    1991 Honda Civic si 1.6L
    I have the old style cable clutch, is there a way to adjust the cable.
    When cold the clutch shudders a bit on start off, but after it warms up after a few shifts its fine.
    Thanks
    Vic.
  2. phyregod
    phyregod !!YTINASNI
    Central Texas
    Cable adjustment is on the cable itself where it attatches to the transmission. lift up on the knob and turn it.. But I would check the freeplay and adjust accordingly. A haynes or chiltons should cover the specs. I don't have either on hand.
  3. vic42
    vic42 Junior Member
    Thanks phyregod, i had a look at the cable and there seems to be a bit of play but i not sure if its to much or just normal play. I'll take your advice and look for a manual.
    Thanks
    Vic.
