Adjusting the Wastegate
Discussion in 'Forced Induction' started by import_racer, Oct 21, 2002.
  1. import_racer
    import_racer Member
    The nut on the wastegate, to adjust boost, is it, the higher the nut (loosened) the lower the boost, or is it the lower the nut (tightened), the lower the boost?
  2. Slo86GT
    Slo86GT Super Moderator
    Memphis - Hellhole of the South
    The more you tighten fown the wastegate adjustment bolt/nut, the higher the minimum boost setting.
    For example, take the bolt out completely, it might hold 6 PSI if the spring is a 7 psi spring. If you tighten it down a good bit(careful not to compress the spring too much), you might squeeze 9 psi out of a 7 psi spring.
    Hope this helps.
  3. CRX-YEM
    Wallingford, CT
    What kinda turbo are we talkin ??? my info will prolly help you get a better answer
  4. import_racer
    import_racer Member
    I have a stage 2 rev hard turbo kit with T3/T04B Hybrid Turbo on a second gen B16 in 92 Hatch.
  5. SolReaver
    SolReaver Senior Member
    isnt the t3/t04b the hella big one? what trim is it?
  6. pissedoffsol
    thats average... big is t66 and t88's
