projectxspeed
When I pull b18b engine I need to do the timing belt. I was going to replace the water pump and the oil pump for good measure for my turbo project. Should I use LS pumps or should replace them with something else. If so what timing belt would I use. I am only going to consider Honda OEM parts.
