advice plz
Discussion in 'Civic and del Sol - EG and EK' started by mrdrewlash24, Apr 12, 2010.
  1. mrdrewlash24
    mrdrewlash24 New Member
    just got a 1996 civic ex wat shud i do to it , i wanna make 200-250 horses wit no tubro any ideas
  2. 8secHonda
    8secHonda New Member
    NOS will help u .. lol i personally am uneasy bout nos i seen what can happen to a car if it isnt installed properly.. i assume u have the 1.6 vtec right ? that engine makes 127hp @6600 rpm youll need more than nos the acheive ur goal.. maybe some headwork and prolly aftermarket cams.. good luck bro
  3. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    well, with that kind of hp goals and no turbo, your gona have to build the shit out of any motor you swap in there other than a k series, but if you swap to go b series it could be had with a supercharger or built out the ass. or for around 10 grand drop in a k series with k pro and your done.
  4. ricksautomotive
    ricksautomotive honda dealer tech
    lancaster, ca
    yeah i have a project similar to yours. a word of advice would to research your build. things like cylinder sleeves, custom pistons with skirt coatings, double oil er wrist pins, high performance connecting rods, head work, performance head bolts, fuel system set ups, throttle bodies, possibly balance shaft removal, compression ratios, and more will have to be researched. do you have a budjet for this build? 250 hp cannot be done easily without a budget of like 7 grand minimum
  5. Dark93DX
    Dark93DX New Member
    B.C.
    Go K-series.
  6. BrutalB83
    Rochester Hills, MI
    Answer this first: what is your budget? (i.e. how much money do you have to spend on this?)
    Answer that question, and then we will be able to tell you if your goals are even possible or not...
  7. mrdrewlash24
    Thanks dudes but I anit got seven gs so I guess ill go wit the b series or a k swap wit headers ,pistonsand exhuast work maybe a small turbo not to big cuz they a a pain to take car but anymore ideas I also want it to handle these moutain turns like it was there
  8. AHHVTEC
    Alabama
    whats your budget
  9. Dark93DX
    Dark93DX New Member
    B.C.
    Well there is a big difference between swapping a B-series vs a K-series, I suggested K-series b/c you never gave a budget, only an NA Hp goal.
    whats you biggest concern? Money? 200-250whp? Turbo or NA?
