AEM cam gears
Discussion in 'Engine Building' started by khai_tuan_nguyen, Feb 27, 2004.
  1. khai_tuan_nguyen
    khai_tuan_nguyen Senior Member
    I am getting aem fpr and fuel rail. So i thought what the heck why not the cam gears too? I know people don't like the 3 bolt design, but has anyone actually had any problems with it?
    Khai
  2. B18C_NA
    B18C_NA Banned
    AEM slipped on me a couple of times. Get Skunk2, HKS. I'm running on TODA's right now, very accurate.
  3. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    i have guys running for 2 years on them without a prob.
    You look them over when yopu look over the rest of your car and tighten as needed
  4. E_SolSi
  5. Jeef
    Jeef NO MA'AM Moderator VIP
  6. Smonkeyboy
    Smonkeyboy Senior Member
    Spokane, WA
    you dont want the AEM cam gears, as they are only three bolt, get some that are 6 bolt. (Toda, Skunk2)
  7. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    another issue is also how much adjustable the gears can go, todas won't let you adjust them more than 5 degrees in either diretion, so that means if they slip, chances are your valve train won't hit your pistons and go cluk cluk.
    Go with the todas. very nice and worth the money.
  8. E_SolSi
  9. JDMilan
    Boca Raton, FL
  10. ek9r
    ek9r Senior Member
    Long Island NY
    yep, well said
  11. JDMilan
    Boca Raton, FL
  12. khai_tuan_nguyen
    What about the aem fpr and fuel rail, will i be ok with those though?
    Khai
  13. Sergey P.A.
    Sergey P.A. Senior Member
    253 Tacoma
  14. JDMilan
    Boca Raton, FL
    if you need more fuel, get larger injectors and a fuel pump, the stocke oem honda fuel rail on b series motors will support in the area of 400-500HP, once you throw the pressures around, honestly it creates a decent amount of stree within the fuel rail.
  15. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    back to the issue of how much there cam gears suck. My freind on his LS had a set of the AEM's, and when he went to adjust them, ever bolt had striped. Then he got his easy-out out (lol) and tried to remove the bolts. All that did was ripped the bolts to peices instead of griping them and removing them. Why is this? AEM's bolts are extremly shitty. They could use playdough and it would be harder bolts. He later replaced ever bolt with some good grade 8 bolts, and now he hasn't really had any problems.
    No matter what brand you have, put locktite on the bolts, and check them offten. Pill_PMD had the Skunk2 gears, and had them slip on him because the bolts lossen up.
