Aem Ems Injector Question
Discussion in 'Forced Induction' started by Sprocker, Feb 11, 2003.
  1. Sprocker
    Sprocker Senior Member
    Ok well I finally went ahead and got the AEM EMS and I am getting ready to get my injectors, I am thinking either 440cc or 500cc's but what I am wondering is do I need to upgrade my fuel pump or will the stock pump be ok, anyone know what the presure at the fuel rail generally is, and don't hondas use Saturated injectors. Thanks for any suggestions.
  2. D See 2
    D See 2 Senior Member
    Baltimore, MD
    with the flow of the injectors you're comtemplating, i would suggest you upgrade your fuel pump.
  3. pissedoffsol
    depends what year honda- some use peak/hold, some are saturated. see the FAQ forum.
    as for the pump- def upgrade
  4. poid
    poid Member
    Just to hijack the thread a little, i didnt see in the FAQ forum what the injectors in a F22B1 were, are they peak and hold or saturated?
    Also, if they were saturated and the ECU to be used supports peak and hold, is it still necessary to have a resistor box?
    Cheers :)
