AEM Filter cleaner?
Discussion in 'General Tech and Maintenance' started by HatchSpeeD, Mar 19, 2005.
  1. HatchSpeeD
    HatchSpeeD ...Hi...
    Beantown
    I have a aem short-ram and the filter looks pretty dirty. Is it alright to clean it off in a bucket of water or what is the best way to clean it? Do you have to use the aem filter cleaner?
  2. B18aCRX
    B18aCRX Senior Member
    Central Coast, CA
    You should use the K&N or AEM filter cleaner because the oil is actually what helps catch the dust particles.
  3. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    There are two different products here. The filter cleaner, and the filter oil.
    The cleaner isn't necessary. It's basically repackaged dish soap that they're selling to you at a huge markup. Yes, you can use dish soap and a high-pressure stream to clean your filter. That's what I do.
    However, as B18aCRX suggested, you should use the oil after the filter is cleaned and dried, because it does most of the filtering.
  4. B16CRX
    B16CRX Senior Member
    Greenville, SC
    I beleive the K&N filter Charger kits are around $15-$20. Worth it IMO.
