CRX_B16B
I was just wondering what your thoughts are on this system. I was just reading about it and it says it has a boost controller on it that activates silonoids and you can set it for certain RPM's so in theory you could activate Vtec at what ever RPM you want with it insted of boost also it says you can have a boost override switch in the cockpit so you could manually activate Vtec, does that seem to be logical to anyone else? I almost busted a load when I thought about that. so let me get some feed back Thanks
