Canuck 93 Civic Si
The only non-oe part in the AEM rear disk conversion kit is that bracket that holds the calipers in place. This bracket is just a piece of 3/16 or 1/8 steel sheet, with all the holes in place for the calipers and the four bolts that would normally hold the drum back plate on. If some industrious person, suck as myself, were to take one of these brackets and make a few copies of them, would anyone be interested in them for doing a rear disk conversion? The only part you would need to get to complete the setup would be calis, rotor, e brake cables and brake lines ( brake lines may be included in the kit because i dont like using used hoses and im sure some other people dont either )
Please let me know your oppinions
