AEM Wideband UEGO Controller **Sale**
Discussion in 'CorSport' started by CorSport, Aug 20, 2009.
  1. CorSport
    CorSport Member
    This sale price will be good until the end of august.
    CorSport Online Store: AEM - 30-4100
    AEM Wideband UEGO Controller Only $210.00 shipped
    A wideband UEGO sensor controller accurately monitors Air/Fuel ratios (AFR) during the tuning process to prevent a lean fuel mixture, which could lead to engine damage. AEM has combined its single-channel wideband UEGO controller and gauge display into one unit, uniting unsurpassed AFR accuracy and control with an easy-to-read interface. AEM’s Gauge-Type Wideband UEGO Controller features a digital LED display and sweeping LED “needle” that changes colors as AFR changes from rich to lean. The unit’s 52mm (2-1/16”) gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere.
    Ideal AFR monitoring tool for EFI and carbureted applications, and engine dynamometers
    Does not oscillate AFR reading like narrow band sensors
    No laptop required for monitoring!
    Bosch sensor included
    Accurate to 0.1 AFR
    Reads in AFR or Lambda via a switch in back of gauge housing
    24 Color-coded LED display lights provide immediate reference to engine’s air/fuel ratio (AFR) or Lambda ratio
    Integrated three-digit display reveals AFR or Lambda in real time
    User-programmable 0-5v analog output included for use with data loggers and virtually any engine management system
    Serial data stream included for output of AFR (RS 232)
    Shipping is included in the price
  2. Briansol
    great price!
  3. CorSport
    CorSport Member
