aftermarket steering wheel..no horn?
Discussion in 'Civic and CRX - EF' started by HATCHET_HONDA, Jul 9, 2008.
  1. HATCHET_HONDA
    HATCHET_HONDA scottie fizzle
    hobart, indiana
    i installed a momo steering wheel on my 90 civic hatch..is there a way to keep the horn? i had to disconnect the copper tab on the colomn cause it would make contact with the hub adapter and the horn would go off when i made a turn,, any suggestions?
  2. Bkkfarang
    Bkkfarang New Member
    Bangkok and Shenzhen
    strange issue . normally you cab just bend the tabs connecting the horn wire to avoid contact
  3. HATCHET_HONDA
    hobart, indiana
    ive tried that.. but in a day the cotact tab is touching the middle of the hub again and the damn horn is goin off
  4. Bkkfarang
    touching the middle ? could th wire be too short ?> and when you turn its getting pulled tight ?
    just a thought !
  5. HATCHET_HONDA
    hobart, indiana
    the wire isnt the problem its the copper contact tab..ok, the factory wheel has a copper ring on the bottom that makes contact for the horn..well the new hub is ALL metal so not only does it touch the bottom as its supposed to it also touches on the center of the hub when the wheel is turned..thinkin of just unhookin the tab and sayin fuck it
  6. autox 89 dx
    autox 89 dx Member
    SF bay area
    fuck a horn thats how I roll :D
  7. whiterabbit06
    Crestview, Fl
  8. HATCHET_HONDA
    hobart, indiana
    yep.. thats what i figured... no one i know has a horn that works either
  9. HATCHET_HONDA
    hobart, indiana
    just an update....i recently chucked that shitty ebay hub adapter and have installed a quality momo brand hub. whattya know..my horn works fine!! has been for like 5 days now...sometimes you get what you pay for i guess
  10. Bkkfarang
    glad you got it fixed , but your right at times you do get just what you pay for
  11. HATCHET_HONDA
    hobart, indiana
    yep.. the new hub was like 80 bucks but it looks alot better now and the damn horn works! well worth it indeed :)
