aftermarket stereo not working
Discussion in 'Civic and del Sol - EG and EK' started by jmills10, Jan 2, 2010.
  1. jmills10
    jmills10 New Member
    Independence,Missouri
    i have a sony xplod radio that was working one day and is now not working. followed all the same wires for everything and it just quit working. need some help...
  2. lostsoulzprophet
    lostsoulzprophet delslow
    georgia
    Ok most likely you blew a fuse. check under the dash , or under the hood. depending on your car. most radios run off of two fuses. most ones that blow are under the dash. If its not that, power wire can have a short. or ground is not grounded properly. If it is none of those you just have a bad radio.
  3. jmills10
    jmills10 New Member
    bad radio. thanks man.
  4. lostsoulzprophet
    georgia
    no problem so guessing you fixed it.
