Age old question
Discussion in 'HYBRID -> ED-EF / DA' started by Airgetcha, Aug 22, 2005.
  1. Airgetcha
    Airgetcha Junior Member
    set up: B16A CRX/4 into 1, 2 bung headers.
    Question: can I use the 4 into 2 into 1 crx headers for sale on ebay with my B16A?
  2. formby
    formby learning in progress
    yeah you can.....but you need to take it to an exhaust shop and have them weld the o2 bungs on the right spot.....
    or buy this
    http://www.hasport.com/Products/Headers.htm
  3. phyregod
    phyregod !!YTINASNI
    Central Texas
    NO!! D-series headers will not fit a b-series.
  4. Airgetcha
    ok, now I am confused!
    Here's a little more info. Currently, my 4 into 1 header hangs to low. The lower two tubes are smashed to hell. The car still runs ok, but I'm sure I am losing some performance not to mention some sort of unequal backpressure from cylinder to cylinder. Not good! What is the solution HONDA GODS??????
  5. phyregod
    phyregod !!YTINASNI
    Central Texas
    Get a 4-2-1 header for a b16..
    If you buy the "crx" headers from ebay you will get headers that fit a d-series. They will not bolt up to your motor.
    I think you should be looking for b16 Del Sol headers..
    Can anyone back that up? I'm not certain.....
  6. formby
    .........the reason the header is low is because of your mounts..
    as long as its for a b series youll be fine
    ..i have a cheap 4-1 focuz header and its a little low....but a 4-2-1 i think it will sit just as low........
    and a b series header wont fit a d series....
  7. reckedracing
    reckedracing TTIWWOP VIP
    NY
    get the shield for the exhaust...
