ahhhhh no vtec...
Discussion in 'General Tech and Maintenance' started by ej11, May 20, 2005.
  1. ej11
    ej11 Member
    SO CAL!!!
    does anyone know the part # for the lost motion assembly for the itr 2001
    my car is reving over 5000 and nothing,i check the vtec spool valve and it seem to be working fine...has anyone had this problem???
    thanx in advance.
  2. jamesA
    First thing you should do is check your oil.
  3. VTECin5th
    VTECin5th Administrator
    Phoenix Az
    ^word.
    I used to know if i was low on oil when my VTEC turned on at 6k instead of 5k.
    Yea i could hear my single cam vtec :lol:
  4. ej11
    ej11 Member
    SO CAL!!!
    4.2 qts. right...
    i installed 2001 itr intake camshaft with valve springs, into b16a head.
    i also took off the cams to inspect the lost motion assembly and the #one intake side is not moving freely,so need part # for that...
    thanks in advance...
  5. Taco15
    Tallahassee Fl
    i thought it was 3.5 qrts!? :blink:
  6. 2naboy
    2naboy Member
    yea your lost motion assembly will do that I had it happen to me before but sorry i dont have a part number. btw you should check your manual because, I'm pretty sure your engine dont need 4.2 quarts unless there is something you aint telling us.
  7. ej11
    ej11 Member
    SO CAL!!!
    my bad ((((3.5 qrts.)))) :D
    replaced the lost motion assembly, and vtecs back...
    thanx for the heads up on the qrts!!! hehe.
  8. driverunknown
    driverunknown Senior Member
    My manual says 4.2 U.S quarts and 3.5 lmp quarts, so which is it?
  9. driverunknown
    ok well they would both be the same quantities, but the If you get them mixed up then you should have an engine that's low on oil right?
  10. pissedoffsol
    imp = impreial. unless youre not from the us, this means nothing to you :)
  11. driverunknown
    So all the above guys are running low on their oil?
