air bag and horns????
Discussion in 'Civic and del Sol - EG and EK' started by hondaFTW, Sep 30, 2008.
  1. hondaFTW
    hondaFTW New Member
    Katy, TX
    ok, not too long ago i noticed that my srs light came on but i didnt pay much attention to it. but now my horns arent working either! could this mean that the wiring in my steering colum messed up? before all this happened it was making a wierd noise when i would turn, right behind the steering wheel
  2. 4U2H8ME
    4U2H8ME Beer its whats for dinner
    BRONX, NY
    Sounds like the cable reel/clock spring has gone bad and needs to be replaced. it's the unit behind the steering wheel that inflates the airbag and controls the horn.
  3. hondaFTW
    hondaFTW New Member
    Katy, TX
    great. if its not one thing its another. ok well i guess ill give that a look at and replace it
  4. phyregod
    phyregod !!YTINASNI
    Central Texas
    Just get a new steering wheel off of ebay, will be much cheaper that way.
    Good call 4u2h8me.
  5. JDMB20Coupe
    JDMB20Coupe Powerd With 1 Cam
    Chester, VA
    get you a good lookin itr streerin wheel thats non-srs
  6. hondaFTW
    hondaFTW New Member
    Katy, TX
    where can i get one of those?
  7. awptickes
    MD
    Let's assume his car is a street car:
    If his car has SRS currently, and he disables that system, his insurance could ream his ass. Also, driving a car with SRS disabled is illegal in most states.
    Just get a wheel with SRS. Easier, and legal too.
    Let's assume this is a dedicated track car:
    If he removes SRS, he's removing an important safety feature. The OP should perform a personal sanity check on this one, then check with his tech inspector.
  8. hondaFTW
    hondaFTW New Member
    Katy, TX
    im with you there and thats kinda the reason why i havent bought a steering wheel from ebay. so there are aftermarket steering wheels with srs?
  9. awptickes
    MD
    No. The SRS is so precise that I wouldn't trust an aftermarket wheel with an airbag. The difference from it saving you to it killing you is only a couple Mg of NaN3. Not a real large margin of error.
    Honestly, I've had too many close calls as it is, and I'd prefer all of my safety systems to be in good working order in case something goes sideways on me.
    Besides, most insurance companies can take the removal of an SRS to mean that you've changed it into a "Heavily modified race machine" and then refuse to cover you. Your state-inspector might fail you too, if your car doesn't have an airbag.
    Unless you have a restraint system that will protect you in instances where the airbag would deploy, don't remove the airbag(s). Generally this means a 5 or 6 point harness properly installed, and a FIA Approved bucket seat with head restraints. That's a lot of money just to remove your steering wheel. Not to mention how much it sucks getting in and out of a 6-point every time you go out to get some milk....
  10. hondaFTW
    hondaFTW New Member
    Katy, TX
    :werd: i rather stick with my airbag, especially since ive had a couple of close calls myself.
