Air Fuel Gauge Install
Liquidblaze
I need help, I am starting my turbo project and I am installing my Air fuel Gauge and I don't know what O2 sensor wire to tap into. I have a 98 Civic DX.
Thanks,
-Chris
you should only have (1) one wire o2 sensor. tap into that wire... and dont expect a reading right away. those oxygen sensors are not heated and you have to wait for them to warm up in order to get a signal.
I am installing this tonight so if anyone can help i would greatly appreciate it.
ther's 2 white wires one of them has a black strip on it.
it the one with the black strip.
yep not it. if you have an obd2 then it's the white/blackstrip.
If obd1 then the white wire
black wire to o2 sensor solid white to fuse that comes on with switch one body ground and one ground to something in circuit likestereo ground
