Air/fuel Gauge
Discussion in 'ECU's, Electronics, and Tuning' started by IDMaxGuy, Jun 5, 2003.
  1. IDMaxGuy
    IDMaxGuy Senior Member
    MO
    I just bought a Auto Meter Carbon Fiber Air/Fuel guage today. for 30 bucks, couldnt pass it up. Anyways, I know its simple to install, I just need to know where my O2 senser wire is, on a 1996 Accord EX, VTEC. Cause thats what i tie the purple wire into right.... thanks in advance.
  2. pissedoffsol
    its either on the header, or down by the cat
    kinda looks like a sprak plug... only fatter... and stuff :)
  3. IDMaxGuy
    MO
    thanks a bunch, is there only one wire coming out of it im guessing
  4. IDMaxGuy
    MO
    OK im doing htis again, only this time on a 92 Prelude... OBD1... i doubt the wire is the same color as my 96 OBDII accord... or is it, anyone know this...
  5. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    holy back from the dead post batman!!
    http://www.hondaswap.com/~pills/obd1guide.html
    scroll down a bit.. that's for an obd1 ECU.. i assume that it should be identical to my del sol
    but the o2 will be a four wire.. 2 black heaters a green and a white.. you'll want to hit the white one
  6. IDMaxGuy
    MO
    i love you, ya it is the same as OBDII
  7. StyleTEG
    StyleTEG Senior Member
    Keep in mind the ground must be run to the ECU ground. Anyplace else and you will get interfearance and an inacurate signle. (tons of bars will light up instead of just 1-2).
