Air/fuel Guage
Discussion in 'General Tech and Maintenance' started by Drenni, Apr 6, 2003.
  1. Drenni
    Drenni Senior Member
    I'm trying to install a air/fuel guage in my car and I followed all the instructions and it does'nt work. Is the air sensor in the car not working or how do I know if it is. I conneced it and it goes on and off like crazy. Has anyone had the same problems...
    :spin:
    If anyone could give an opinion
  2. liquid00meth
    liquid00meth Senior Member
    Laconia, NH
    check your power and ground
  3. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
  4. Drenni
    I'm installing the A/F guage into LX civic 90, I'm coverting the car into a ZC. But I wanted to install the gauge before the swap. I did check the power and it's not that but thanks anyways guys. :D
    If anyone knows or has any other ideas please :(
  5. CRX-YEM
    Wallingford, CT
    what do you mean by goes off crazy, are you using an autometer gage (one with the LED's )
    if so you've prolly connected it correctly. you've got to remember how a 02 sensor works. It changes it's voltage rapidily from 0-1V a single LED will almost never been lit by itself. the display will always jump around. an air/fuel ratio meter like this type is really only good for telling you whether you're running rich/stoichometric/lean that's it, it will never give you an exact number.
    for example when you start your car the meter is pegged high , the very last rich led is lit up, and as the car warms up it drops the to the next etc... then at an idel you've probably noticed the display goes back and forth between lean and rich and keeps oscillating. under hard acceleration a few of the rich led's are lit up and while deccelerating a few lean or nothing at all will light up this is completeley normal operation of the gage.
  6. Drenni
    After it's conected the gauge won't light up I know it's conected the correct way and I know that it's actually supossed to move from side to side saying if it's rich or lean (it's autometer with all the lights) I thought maybe the sensor was not working I mean the Oxygen sensor the goes to the header.
    Thanks guys
  7. pills_PMD
    New Albany, OH
    mine doesn't work worth shit. if it isnt lighting up and you Are 100% SURE its wired properly.. then i'd try a new O2 sensor
  8. D See 2
    D See 2 Senior Member
    Baltimore, MD
    you must wait for it to warm up with a one wire o2 sensor. they are not heated like the 4 wire or 3 wire ones. start your can and let it come to running temperature and if it still reads nothing and youre sure everything is hooked up okay, replace the sensor and/or the guage.
  9. CRX-YEM
    Wallingford, CT
  10. liquid00meth
    Laconia, NH
    let her warm up, werd, if it still doesn't work check the GROUND wire. power is useless with no ground
  11. hondasportag2002
    hondasportag2002 Junior Member
    :ph34r: o your car there is four wires near the o2 senser the white one is for the o2 if not that check the power and the ground if you did all that its broken. my name is jeremy you can email me at hondasportag2002@yahoo.com for any more info
  12. Drenni
    I made it work it's that dam O2 sensor but thanks guys for all thr info, it help out great believe me :D .
