Air/Fuel Mixture
N/A b18c1
Mysterious
Well, this is a call out for Blanco but anyone is welcome to answer my problems...
I have a D16z6 in my hatch and I don't know the transmission...Leaks oil under the dizzy but no where else. Here's the other problem...Seems like the motor is taking in too much air and not enough fuel burn...Car does not pick up at all once in 5th gear very slowly....more gas, more air, no go... Timing is right on spot...
i was under the impression 5th gear is cruise gear,your not supposed to have crazy pickup in 5th??
and is the oil leak from the dizzy or under the head??
That's the part I cannot find....I took off the dizzy and clean it but didn't change the seal...I suppose i need to grease everything down ...
